How to start
skoop
I just purchased a boat with a 1995 15 hp Johnson outboard motor. I don't know how to start it. Need specific step by step instructions.
OBJ
Re: How to start
Hey skoop..welcome aboard!<br /><br />First question....is this a remote start, electric start at the engine or a rope start engine?
skoop
Re: How to start
Thanks for answering! - It is a rope start engine
OBJ
Re: How to start
OK skoop....<br /><br />Connect the fuel line to the engine. If the tank is equipped with a vent, make sure it's open. Squeeze primer bulb till firm. Just a note here...the primer bulb has an arrow on it. It should be pointing to the engine.<br /><br />With the primer bulb firmed up...make sure the engine is in neutral. Turn the twist counterclock wise till it stops...this sets the throttle plate. Pull out the choke lever. Give the rope a pull or two. If all is good on the engine, she should fire up. Push the choke lever back in.<br /><br />EDIT: If the twist grip has a red buttom on the engine of the handle, don't forget to have the safety key in place before starting.
skoop
Re: How to start
Thanks a lot! That is just what I needed...and I will be looking for a manual soon.<br />I appreciate the help
Re: How to start
skoop make sure it has a water source, garbage can on in the water on a boat. starting without will kill the impellor (water pump) and your engine.
