Re: 2002 115 johnson fouled plugs
I'd see if your local dealer or prop shop would let you trial run a 17" pitch prop and get the rpms up in the recommended range first before we chase any other problems.However ,as propped,I don't feel would contribute to the low speed idle problem you describe above.That is likely a low speed carburetor issue which needs to be adjusted in gear in water.<br /><br />BTW if your prop is a sst it is stainless.If it'll pull a magnet,that would confirm.
