Old problem was the buzzer would go off. So, I checked the buzzer per forum suggestion. It was indeed hot. Then it was suggested that I check to see if the line was clogged, I did that. Still weak stream. Then it was suggested that it may be a t-stat. So I removed and replaced that. Then it was suggested that it was the water pump. That was removed and replaced. <br />Note: The old water pump looked as good as new, unknown when it was replaced.<br /><br />I am still getting weak stream, the buzzer does not go off but I don't want to run it long enough for it to go off because of the weak water stream. <br /><br />HELP PLEASE, I have run out of options. Also, I have blown with compressed air through the water passages inside the jacket. Also, no corrosion was found.
