This engine as not been run for over 10 years, last time out it seized due to water impellor failure.Engine freed off as soon as it cooled.<br />I decided to try and get it started again as the piston and rings look ok and compression was over 110psi with oil squirted into bores, rings look ok through side plates. I replaced water impellor, took flywheel off and reset points and get sparks at both plugs, cleaned carb and inspected copper air inlet flap valves they look ok. But she refuses to start, I tried squirting wd40 into carb and easystart just get the odd ignition fire then dies. I wonder whether the crankcase seals are leaking? there is what appears to be a pressure balance pipe betwween the top and bottom crankcases, when I dissconnect this and pull the engine over some drops of fuel blow out, is there any way I can check the crankcase precompression? Any other ideas ?
