ballistic ss props
punchy
Any opinions on Ballistic ss props? I have one on a 1992 115hp rude 13 3/8 x 19.I can't tell much difference.<br />Another question, will a tach for an 4 cyc. auto work on a outboard?
Dhadley
Re: ballistic ss props
Can't tell much difference between the Ballistic and what? Let me know if you ever need another one. <br /><br />Use a good quality tach made for what you got. Trying to "make do" can lead you down the wrong path when setting up your rig. And with todays fuel that could get expensive. Get one from OMC or BRP, you'll not regret it.
punchy
Originally posted by Dhadley:<br /> Can't tell much difference between the Ballistic and what? Let me know if you ever need another one. <br /><br />Use a good quality tach made for what you got. Trying to "make do" can lead you down the wrong path when setting up your rig. And with todays fuel that could get expensive. Get one from OMC or BRP, you'll not regret it.
sorry.<br />Difference between aluminum 13 x 19 that came on motor new and the ballistic.<br /><br />the tach stopped zeroing, now when motor is shut off the needle is below the zero.The needle still move but the rpm is off .guess its time for a new one.<br /><br />who is BRP ?
Dhadley
Bombardier Recreational Products bought the remaining rights to what was OMC.
Texasmark
I bought a used boat recently with a Billistic on it and am now in my 3rd one. It came with a 17P and then the 21 wasn't quite enough and finally the 24.<br /><br />For what I do, I like it fine. Would I consider another and would it work better? Dunno.<br /><br />But, for me, why spend any more money.<br /><br />Mark
JB
Moving to Prop Forum.
