scubaman67
Thread starter- Joined
- Jun 4, 2002
- 43
1994 v4 140hp run in salt water, sat for 5 years. Bad Bad previous owner. tried firing up with the muffs on, all good except no coolant flow, i think. nothing out of pee hole, exhaust holes on side of lower unit, or from prop. not a drop from any of those. replaced impeller, thermostats, pulled heads inspected water jackets. still not a drop of water. ran engine without thermostats, still not a drop. should i suspect a clog in copper tube, seems like it seals with water pump. Is there some seal where the copper tube meets powerhead. suspect leak, clog? Would this require me to remove entire powerhead from pan?thought I should try running motor without lower unit on with water supply connected directly to copper tube--good idea? you guys think that running the engine in a barrel would be better than the muffs?
