1979 85hp Johnson V4 Seahorse<br /><br />Recent Repairs:<br />Replaced starter and solenoid<br />Replaced spark plugs/cleaned carb<br /><br /><br />Current Problem:<br />Engine starts fine, idles fine, and will run like a scalded dog for miles ... then goes to what seems like half power. Will max out rpm (9) using throttle lever only, however, when put in gear and under load, only gets around half as much power(4). Will spit and sputter sometimes, then resume normal running, until it happens again. Have tried with two different fuel sources to rule out bad fuel. Fuel supply from tanks through filter is ok. Just cleaned the carb, replaced spark plugs and wires. Possible power pack? coil? or am I missing something? Any help would be greatly appreciated.
