87-50hp is vro pump fuel pump?
thehermit
I recently took off the VRO pump and both carbs. I am looking to disconect the VRO pump entirely from this point forward. I was wondering is the feul pump part of the VRO pump? I was looking around the motor and did not see the typical pump. This leads me to my next question. Can I install a typical fuel pump in its place?<br />link:<br /><br />Sorry hermit....to links to iboats competitors.<br /><br />If so where would you mount it?<br />Help is needed....so many of the hoses to the VRO pump are busted and damaged I am debating if I need to put humpdy dumpdy back together again.
OBJ
Re: 87-50hp is vro pump fuel pump?
The fuel pump you will need is PN438556. It will mount on the port side of the engine....look for two screw holes with a plug screw in between...bout mid way up on the block. You will also need a plug to plug up the hole the pulse limiter was connected to. A brass pipe plug will do. A length of hose from the fuel pump outlet to the carb fuel manifold will get you fuel to the carbs.
thehermit
Mod 2....oops sorry!<br /><br />OBJ, Thats good news. I did a little more research on this and it looks feasable. Is it the way to go or should I try running the VRO fuel pump? My gut tells me go new!
thehermit
OBJ...I orded that pump but am still looking for where it mounts. I can see one screw hole? I'll keep looking I guess
