MOcountryboys
- Joined
- Jun 13, 2006
- 1
Hi, new here...been reading the posts & appreciating the all the good advice.<br /><br />Recently purchased a boat....1965 Newman 16' Runabout with a 1965 Johnson 60 outboard, <br />#VXL-11C (eBay $152.50 YEEHAA)<br /><br />The previous owner tells me that the engine does run, but not well. It will run fine in a test tank, but get it out on the water & it will not run more than half speed. He thought it was a carb problem. <br /><br />Here's what he said he's done to it:<br /><br />New points<br />Checked timing<br />New Distributor<br />Checked Compression<br />Tune-up Kit<br /><br /><br />When I got it home & looked it over, I noticed something a bit odd...one of the spark plug wires had fallen off the distributor. When I looked at it, there is no connector on the distributor end, just stripped wire folded over the wire shaft & pushed up into the dist. cap. The other two plug wires I checked were done the same way--haven't checked the 4th.<br /><br />According to other forum questions & answers, it seems like the wires should have a threaded terminal on the distributor end. Is that right?<br /><br />I'm contemplating tearing the distributor down to get those terminals out & re-soldering them to the plug wires.<br /><br />In my (completely) inexpert opinion, this sounds like something that could cause the engine to not run well under a load--pretty much what the previous owner described.<br /><br />Any suggestions? Or am I following down the wrong trail....I've got the manual ordered, but not here yet...but I'm anxious to get it up & running right & on the water.<br /><br />Thanks,<br /><br />Tim Holloway<br />Lake Killarney, MO
