replacing spark plug wires on 95 150 oceanpro
crazy charlie
I need to replace 2 spark plug wires on my 150 ocean pro and it appears that I will have to do some disassembly to get one of the wires on and off.Do I just take the 2 screws out and pull the module away from where it is connected to have enough room to get the old wire off and the new one on?? Im sure module is the wrong term.Charlie
angus63
Re: replacing spark plug wires on 95 150 oceanpro
Remove the ignition coil pack for the cyl you are fixin' and remove the wire you are replacing. Each coil pack is for two cyl's, so be careful what goes where.
crazy charlie
Thanks Angus.Thats what I thought but I wanted to be sure there werent any steps I had to do first as precautions.Charlie
