Don Powell Sr
Thread starter- Joined
- Jun 13, 2006
- 5
My son has been working on our 8 hp because it will start and run beautifully at idle, and at about 1/3rd throttle, but stops abruptly when wot is applied.Squeezing the bulb, chocking, does not keep it running. If returned quickly to 1/4 throttle, it will run. The motor sat for 2 years, and he thought the carb was fouled. He has checked, or done the following. New tank, fuel line, connectors, rebuilt carb, replaced fuel pump, cleaned filter. I looked at it and found good looking spark on both, installed new plugs. I did not have a compression gauge, but both cylinders seemed to have good compression. I looked at the linkage and advance looked ok. I will try to obtain a wheel puller to look at the coils and points. This motor has been used very little, but now we need it. Any ideas of what to look for.
