Re: After installing new impeller
Since you didn't post model number, we can only guess....is this an electric start motor?? Do you have spark to the plugs? Fresh fuel mix, vented tank. Primer bulb firm? If you have spark, try spraying fuel mix from spray bottle into carb throat, will it fire then? Kill switch engaged? Possibly water at the bottom of tank got sucked into the carb.<br /><br />When the motor quit, was this before or after the impeller replacement? If before, did the motor overheat? Do a compression test.<br /><br />If the old impeller flew apart, it's possible that parts of it got pushed up the water tube and could block cooling water to the powerhead.You won't know if you have a blockage until you get it running, just watch the temps when you do get her going. The impeller replacement would not prevent the motor from starting.
