1972 85 hp evinrude wont fire
PHUGUET
when i try to turn it over the prop spins. it has electirc shifting which i can not seem to get the prop to disengage. absolutely will not fire. the solenoids appear to be functioning with the push button shifting. can anyone shed some light on my ignition issues. does anyone out there have one that can give me some input? thanx
alden135
Re: 1972 85 hp evinrude wont fire
It's spring loaded to default to forward until it starts.
PHUGUET
thanx for the info. any ideas where else to look? i have 275 volts coming out of coil into stator. enough juice to fry my volt meter coming out of the plug wires.... is there a kill switch or an obvious ground i should be looking for? any input would be helpful... thanx again.
alden135
I would start with removing, inspecting (under the insulation) and cleaning EVERY wire and connection on that engine. You would be surprised how a wire can look ok outside, and be a green crumbling mess inside. I have a '69 85 hp and had that issue. <br /><br />Use the red search button and you will find LOTS of info on testing that motors components. Adding the member name Joe Reeves will return lots of great answers. He has posted several great "how to's" on those engines.<br /><br />Really ought to buy a factory manual too.
