Rebuilding 87 Merc V-150
Outrage 19
I just got my block back from the machine shop and I am ready to assemble. The book says to apply grease on the crank and connecting rod bearings before assembling. What type of grease should I use?
Kenny Bush
Re: Rebuilding 87 Merc V-150
Man I just douche everything with two stroke while I am assembling. The floor looks like a mess when I am done, but I have excellent luck(or no problems) with all of my rebuilds. I never worry about that white monkey grease working its way out. If you have to have it, call your local dealer for assembly lube. :D :cool: :)
Outrage 19
Ok BushCat thanks for the reply. Would fogging oil be just as good?
KennyKenCan
DO NOT use fogging oil for assembly of engine!!!!<br /><br />Use outboard oil or molly assembly lube ONLY!!!!<br /><br />Kenny
Outrage 19
Thanks Kenny I’ll use TCW-3 oil when I assemble. But I have to ask why not, if fogging oil is good to coat all of the moving parts and keep them from rusting then act as a lubricant when you first start up in the spring why not use it?
