how do I wire a tach without a charging system?
Johnshan1
I have an '86 Mariner 30 hp engine with no charging system, I need to install a tach.<br /><br />I went to the local Mariner dealer who told me I needed to buy a rectifier to go from AC to DC power, which the tach and then charging system would run off.<br /><br />Anyone know what I should do?<br /><br />Thanks<br />-John
Johnshan1
Re: how do I wire a tach without a charging system?
By the way I do have a battery on board, and already have a tach. Im assuming theres gotta be some way around this problem, basically just gotta get the signal from the lighting coil to dc right? Then the tach could read from it....<br /><br />Schematic- any ideas? I know you know your stuff.<br /><br />I should be able to figure this out as I went to school to be an electrician.... but im stuck.<br /><br />Thanks for any help. I want the tach so I can get the right prop for this boat.<br /><br />-John
hondon
If your already charging a battery with the lighting coil ,you have to be already rectified as that coil makes AC voltage.The pulses that it takes to make that voltage are what your tach is counting.Problem is the pulse signal on this system is too weak to pick up at the tach.Why not just hook up to an outboard shop tach and take it out for a blast?That would be much more accurate in the first place.
steelespike
Look for tiny tach on the net, very simple install<br /> only about $40.
Johnshan1
My lighting coil does not charge the battery. The battery is not hooked to the engine.<br /><br />I already have bought a teleflex tach.<br /><br />So how would I go about doing this besides buying a tiny tach, I would rather have a standard tach with dial on there.<br />-John
Johnshan1
hondon
Good luck.Without the charging system I don't think it can be done.
Johnshan1
NathanY
Sorry john, it cant be done.
