Drive Shaft Pits and h20 in gear oil???
hallhen
I have pits in the drive shaft close to the water pump seals. I beleive this is allowing water in the oil and there is oil on the pump. <br /><br />Is there anyway to repair the pits without replacing the drive shaft?
OBJ
Re: Drive Shaft Pits and h20 in gear oil???
Hall.....please post your hp, make and year of yer' engine.
hallhen
Mercury 75 outboard - 7.5hp S/N 2813417.circa 1970
eurolarva
Might be able to find a machinest that can do a wrap on it and then resurface it. I am considering having this done this winter. A guy here is figuring about 80 bucks to do the job. Looks like a new drive shaft assembly for your motor is around $400. Might want to call around to see if anyone will resurface yours
azemon
I used to do lots of metal spray jobs for local boat shops here in AZ. Closed my shop 5 years ago. I am building a new shop and will start doing metal spray again soon (summer 2004). Jobs on shafts like yours would be around $85 plus shipping. <br /><br />AJ
