After having sat for a couple months the engine won't fire at all. It was running and starting fine before that. Checked for spark at the plugs and didin't see any. As per the manual I have, put main coil wire near a ground to check for spark, but nothing so we replaced the coil thinking it was the problem. Still no go. The distributor, points, condenser, cap, wires, and plugs were replaced at the beginning of the summer because of some problems and the boat had run great since then.<br /><br />After looking in the manual again I see that their is also a "resistance wire" that goes from the coil's + to the electronic choke. I tried checking it's resistance but I get an infinite reading so I assume that the wire is broken or cut. <br /><br />Couple of questions. What is the purpose of the resistance wire, i.e. how does the current flow through it and how does that affect the coil? If I were to replace it with another wire, does anyone know what gauge I should use to get a resistance of 1.8 - 2.0 ohms which is what it's specd at? <br /><br />Let me know if you need any other info.<br /><br />Thanks
