What year Mercury do I have?
ReelRaider
Just bought a Avon Seasport 4.25 with a 50 hp. Mercury. The Avon is a 1993 and I would like to about the engine. The serial no. is OD233707. I believe it is a classic. Also after running for less than two minutes a steady alarm goes off. Help if you can. Also what is the best gas/oil mix for this engine.<br /><br />Thanks in advance.<br /><br />Allen :p
crazyray2
Re: What year Mercury do I have?
do you have water circulation? is it oil injected?....correct oil in tank?.......and correct level..
Walter
Your engine should run fine on pre-mix fuel with the ratio of 50:1. But like crazyray <br />says...we need more info.<br /><br />Walt
ReelRaider
I just bought the boat - No manuals - Not5 sure what I have yet - Maybe my questions are too early - I find a manual and hopefully figure out what the heck I bought.<br /><br />Thanks for your replies. At least I'm in the right area. You boaters are great.<br /><br />Al
fone_man
Need Model Number to go with serial number!!!!<br /><br />Awaiting your reply....
fone_man
After posting thought I would pull up my database and quess what.......<br /><br />You are the proud owner of .........<br /><br />1993 50 / 50 HP D182000 - 0D279349<br /><br /> :D
ReelRaider
Foneman - Thanks - I hope that's all I need. The year puts me in the ballpark. Now I can address the problem -- Loads of thanks...........<br /><br />Al
