I have a 1975 or 1976 (not sure need to check serial number) mercury 65hp 3cyl. I recently replaced the lower unit which fixed my previous problem. Now I have a new problem. After about 1/2 hr of run time with my new lower unit, the engine stalled and would not power up. By that I mean it would idle(very rough) but would not run at throttle speed. I pulled the motor hood and found that water was pumping from around the top spark plug. I'm assuming a blown head gasket or a cracked cylinder. Someone told me this motor may not use a head gasket as I could not find a listing for one. Can someone help me here? Head gasket? Cracked cylinder? Other? All help appreciated.
