I'm new to this board. Hoping someone can help. I have a 1985 mariner 115hp inline 6.Serial # A180935. Cylinders 1,3,5 aren't firing. I checked the stator ohms per maintenace manual. 6.5 k ohms. A little high but not open or shorted. I also checked the resistance on trigger coils and they were within specs. I swapped switching boxes and problem stayed with 1,3,5. I checked voltage at idle from stator. 1,3,5 was about 35 volts v.a.c.. 2,4,6 was about 140 v.a.c.. I think stator is bad. But, someone I talked to here local said it could also be the trigger. Any ideas to narrow it down would be greatly appriciated.
