Springbok 14ft Aluminum Boat
Raftsman
I have a 14ft wide and deep hull fishing boat. I have an Evinrude 15hp motor. The specs plate on the boat is faded out and I am trying to find the maximum hp I can put on the boat. Does anyone know this. I have been offered a 25hp in return for my 15hp. I tried to pull my 11 year old son on a tube but and can't get any speed. <br /><br />Thanks in advance.<br /><br />Jim
CATransplant
Re: Springbok 14ft Aluminum Boat
OK, looking at Princecraft boats, the successor, their aluminum deep-V boats done come in a 14' version any longer. Their 16 footer is rated to 50hp.<br /><br />Does your 15 plane the boat with you in it alone? Easily? I'm betting that the 25 will be fine on that boat, if it's anything like what I saw in the Princecraft line.
Raftsman
No, I haven't tried going alone. I just haven't found a source that could tell me the maximum rating I could place on the boat. Here in Quebec, Canada, the ministry doesn't permit motors larger that the boat maximum and I can't seem to find the answer.
BF
I don't have one, but there is at least one on my lake 14', springbok with 25 hp merc. Of course he could be over the rating. (?) I noticed another guy has a 14' alumarine with a 30 hp yamaha on it. Boat seems to handle it fine, but I bet it's over the rating.<br /><br />So I don't think there'd be problem with the boat handling it, but whether it's rated for 20 or 25 I don't know. My 16' Naden aluminum is rated for 35, not that that helps you much.<br /><br />If you really wanna know the reating, maybe try looking online for one like yours for sale, and then call and ask the seller what it's rated for.
CATransplant
Any chance you can post a photo here? I'd be willing to bet, though, that it's rated for at least a 25, if it's a deep-v design and wide.<br /><br />Sounds like the Lund 14' fishing boats I see around here everywhere. They all have 25hp or 35hp motors on them.
CATransplant
Here's a photo of the Lund 14' fishing boat. It's rated for 25 hp. Does the design look anything like yours?<br /><br />
alderman
Copied this from another post hear on Iboats, using this my 1965 14 foot starcraft will handle a 40hp, however it gets us around quite well with a 1971 25 hp rude. Hope thiLast I looked, horsepower rating based on a few different principles, but not too terribly complex. The first was a simple formula based on the dimensions of the boat. For mono-hull boats under 20 ft in length, the formula is:<br />Ray<br /><br />(2 X L X W) -90 = rated horsepower<br /><br />Where:<br /><br />L=boat length<br />W=transom width; if the boat does not have a full transom,<br />the transom width is the broadest beam in the<br />aftermost quarter length of the boat.<br /><br />The rated horsepower may be rounded up to the nearest "5".<br /><br />So a 19ft boat with a transom width of 6ft 6 inches should have a maximum HP rating of (19x6.5x2)-90 = 157hp, or 160hp rounded up.<br /><br />Now, a secondary test is a high-speed turn test. A boat must be able to handle a sudden 180 degree turn of the steering wheel at maximum speed with the max horsepower engine (propped correctly) without loss of control or ejecting the driver. If the hull design fails this test, the manufacturer can either lower the horsepower rating, or place a warning label on the dashboard. I believe most opted for de-rated
quoteunquote
I have a 14 Foot Deep Hull Springbok with the original Merc Engine. It's a massive 40 HP engine. You'll be totally safe with a 25 or even 35. Though these are commonly used for fishing today, these were standard water skiiing boats back in the day.
What a great little boat. Cheers!
esobofh
Yeah i'm told he put the 25 on it.. and ended up killing himself and his entire family.
way to go guys.
lavoyg
I also have a 14' Aluminum Springbok.
I called a boat dealer and he told me that the max HP rating for that boat is 15 horse. I then went and looked on the Transport Canada tag and the max HP that Transport Canada alows for that size of boat is taged at 17.5 horse.
Hope this helps.
russbigs
I have a 14' aluminum springbok ski boat and the max is 50 hp, It goes really good. A 25hp should be great too.
