what year is this 50 hp Merc and is the stator toast?
sos
I have recently purchased an older 50 hp Merc the 4 cylinder. I was curious what year it is-serial number 1844663 and since there is no spark at any cylinder is the stator toast? <br />I would greatly appreciate any assistance as although I am a woman I'm pretty handy with a wrench
<br />Thanks
corm
Re: what year is this 50 hp Merc and is the stator toast?
Hi,<br />It is in the 60s. This motor has a distributor on it. It sounds to me like the points are either corroaded or closed up an need to be regapped. Set them at .009-.010.<br />The dist is on the port side of the motor held on by 4 3/8head bolts. The dist spline has a flat spot in it so you can't get it back in wrong.<br />...have fun...corm
sos
Thanks Corm,<br />There is a distributor on the port side. I will follow your directions and proceed with the operation.Hopefully that's the problem I will be in touch. Thanks again I can't believe how quickly I recieved a reply..<br />SOS
corm
email me if you need to. :) ....corm
fone_man
50 hp Merc 4 cyl serial number 1844663 <br />---------------------------------------------<br />1965 Merc 50HP 4 cyl SN 1755549 - 1870388<br /><br /><br /><br />------------------<br />"Keep it between the Bouys & Good Luck"<br /><br />fone_man
fone_man
REVISED:<br /><br />50 hp Merc 4 cyl SN 1844663 <br />---------------------------------------------<br />1965 Merc 500 50HP 4 cyl SN 1755549 - 1870388<br /><br />------------------<br />"Keep it between the Bouys & Good Luck"<br /><br />fone_man
sos
Thanks for the information on the year of my motor Fone Man it should come in handy.<br /><br />Corm I pulled the distributor and cleaned the points with some emery paper. They appeared to be stuck together and covered with a white corrosion. I couldn't find my feeler gauges though but I could tell there was a gap. However after reassembling I still have no spark. Do you think I should have searched harder for my feeler gauges or do you suspect something else. It appears to me that the dist has been opened before perhaps they have had similar problems?<br />I haven't been able to contact the guy I bought it from so I would appreciate any more assistance you could give me.<br />Thanks...
SOS
fone_man
Do yourself a favor when you pick up new set of points... get two!!!<br /><br />I change mine every year... good, bad or ugly... it doesn't matter, then put old set in glove box, then take out glove box set & put in boat toolbox in truck... How many times have I gone to a dock to get gas or beverages, have I seen a guy sitting there bangin away at his engine & 6 kids sweating & spending thier old man's money in bait shop & all he wants to do is get on the water... 15 minutes later he is gone because I take the time to get my tools & put my old set in his & he is ready to go... had one guy offer me $100.00 because his day was not ruined, told him no charge but next time he saw someone broken down... STOP & HELP them & he said he would...<br /><br />Water/Moisture is a killer of metal... even if you cleaned them they still won't start... as for feeler gauges... use 'em unless you have a good eye!!!<br /><br />Best advice I can give...<br /><br /><br /><br />------------------<br />"Keep it between the Bouys & Good Luck"<br /><br />fone_man
corm
Try some 600 grit wet or dry sand paper.Look for the feeler gauge. Before you put it back<br />on spin the shaft to see if you have spark.<br />If the coil cover it soft like neopreem you should replace it. Make sure no wires are grounding out. Leave the ing switch wire off the outside of the dist to elminate the ing switch when you test it. The pts cost $35,the<br />coil is $90 if I remember right, so be sure before you spend your money. If you can.<br />good luck...have fun...corm
sos
Thanks to Corm and Fone Man for your knowledge and time. It is really nice to know that there are still some good people out there willing to help someone who really needs it.<br />I will follow your advice gentleman only this time that distributor will come off in half the time...
<br />SOS
