will reducing prop pitch always lower top end speed?
vesselgreenhead
18 foot commercial aluminum performance V double floor 3/16" boat with 150 mercury. mirage plus 19" prop turning 5000 rpm's at 49 mph(GPS). rpm's are at the lowest WOT range from owners manuel. if i was to drop to mirage plus 17" and reach a better WOT rpm range according to owners manuel (peak 5600), would i loose speed or possibly increase with more rpm's ? thoughts, please.
chads15
Re: will reducing prop pitch always lower top end speed?
Yes you will loose top end speed and gain RPMs. but you will plain out faster.
Jacques321
Chad,<br /><br />It's the other way around. If he lowers his pitch by two inches using the same 3 blade prop he'll gain 300-400 RPMs which in theory should increae speed at the top end of WOT as well as help coming out of the hole a little quicker. Now if he was using a 4 blade prop with a lower pitch he would lose top end speed and come out of the hole much quicker.<br /><br />------------------<br />Princecraft 164(2000)<br />Merc 90-4 stroke<br />Prop:Vengeance SS 16P
JeffSlade
I agree with Jacques321. If you increase your rpm's enough you could actually increase your top-end speed. It really depends on what type of prop you are using now and what you would change to. Rake, pitch, diameter all make a difference.
Mark-C
All sortsa different views. Well, here's another, just based on stuff I've read. If you keep the same diameter, then going to somewhat *lower* than stock pitch improves "hole shot" (initial acceleration), because it lets you rev faster (where your engine is more powerful) when you're moving slower. (Going *much* lower than stock pitch, though, overdoes it, and the prop basically just spins in the water.) If you go somewhat *higher* than stock pitch, you sacrifice even more in terms of low speed acceleration (which is why the stock prop wasn't that high pitch initially), but you go faster at WOT, since with the stock prop at WOT your engine isn't working its hardest. If you go *much* higher pitch than stock, then you reduce the RPM's the engine will go at WOT (again pulling it out of its sweet spot), and increasing the tendency to be more of a drink-mixer than a prop. To understand all this, it's helpful to imagine props with wacky pitches: almost none (you go nowhere, and the prop slices through the water putting no load on the engine), and almost 90 degrees (big load on engine churning the water, but again you go nowhere). So, not only is the ideal general purpose prop a balance, so are the ideal WOT prop and the ideal hole-shot prop.
vesselgreenhead
thanks for input so far. I am going to stay with exact same prop, mercury mirage plus but want to drop to 17" to up my rpm's. Like everybody else, i don't want to loose any speed. the prop has 3 plugs towards the end of the prop from which i understand can be removed to help with hole shots. the prop now 19" has a great hole shot and even slips for a little when full throtle is applied from the start. I'm wondering about 2 things, by changing to a 17" will it slip more and if i remove the plugs in the 19" prop will that give me more rpm's at wot thus not having to change it.
