bassin_baloo
Thread starter- Joined
- Feb 23, 2002
- 2
Hello,<br />PLEASE HELP!<br />I have a 1987 (I think) 90 HP Mercury six cylinder Outboard on a 16 foot fiberglass boat. This rig is new to me as of December 2001. I have experienced the following problems:<br /><br />First, the motor was a bear to start 2-3 minutes of turning the key.<br /><br />Second, the motor would run about 23 mph for the first 15-20 minutes then without me doing anything, kick in and accelerate to 35 mph. After this the motor was fine for the rest of the day.<br /><br />Third, I talked with a local boat mechanic and he said that my problem was bad and that I needed to get it fixed before major problems occurred. I left the boat with him and he made the following repairs: 1) Replaced the trigger assembly 2)changed all spark plugs 3) rebuilt all three carbs 4) replaced one of the switch boxes 5) tested the stator and all readings were within specs 6) he performed several misc. test including a drop cylinder test and some test on the water where he had a box that he could run test with the motor under a load 7) replaced the carb jets with 72,000 8) played with props to see if a difference occurred and all test with props ranging from 17-23 pitch were unsuccessful 9) replaced the fuel bulb and checked all fuel lines.<br /><br />With all these repairs, the motor is worse than before and the mechanic says he has no idea what to do. The motor now is even harder to start than before and boggs down when going from an idle to full acceleration. Top speed is now a whopping 31 mph with rpm's at 3900. <br /><br />The mechanic and myself are at a complete loss. The motor appears to run great just something holding it back! One final note, the compression is 160 on all six cylinders and all six are firing. Also, the timing has apparently been readjusted and is fine.<br /><br />Any and all suggestions are greatly appreciated!!! PLEASE HELP<br /><br />Thanks,<br />Adam
