What year is my Mercury motor?
AFDan52
I just bought an old 1963 Lonestar boat to go fishing with and I'm not sure what year the motor is. It's a Mercury 1100 SS, 100hp The serial no. 1466121 if this is any help. Thanks for your time AFDan52 :confused: <br />[*]null<br />[*]
tema
Re: What year is my Mercury motor?
The records seem to be a little vague on that point, it seems like they produced 100 Hp engines from 1962 on, but the serial no. started with 15 at that time. I would guess it's either 1961 or 1962.
Walter
Don't quote me on this...but I believe Merc's 1100 was produced in 1966 & 1967. It was rated at 110 hp...not 100 hp.<br /><br />Walt
fone_man
1966 Merc 1100SS 110 HP per Grubb's Old Mercs... shows only one year of production.
Walter
Fone_Man...<br /><br />I know the 1100 was mfg'd in 1967...are you saying Grubbs is saying it wasn't? Or was the model 1100SS only mfg'd in '66.<br /><br />Walt
Dhadley
The Merc guide I have shows serial numbers 1464949-1768403 as 1962-63 100 hp but not SS model.<br /><br />Confused? Me too.
fone_man
Check it out... also go to http://www.oldmercs.com/ for further info... Bookmark this site for future reference!!!<br /><br />fone_man<br /><br />Kiekhaefer Mercury 1964-65-66 Models <br /> <br />Model Year Horsepower <br />Merc 1100SS 1966 110 <br />Merc 1100 1966 110 <br />Merc 1000 1964-65 100 <br />Merc 950SS 1966 95 <br />Merc 950 1966 95 <br />Merc 900 1965 90 <br />Merc 850 (90 cu.in.) 1964 85 <br />Merc 650 1964-65-66 65 <br />Merc 500 Jet Prop 1964-65-66 50 <br />Merc 350 1964-65-66 35 <br />Merc 200 Gear Shift 1964-65-66 20 <br />Merc 110 1964-65-66 9.8 <br />Merc 60 1964-65-66 6 <br />Merc 39 1964-65-66 3.9
Chinewalker
Quick question...<br /><br />Was the model number gleaned from the hood or cowling or from the ID plate on the transom bracket? It's entirely possible that the original cowls were damaged/lost and a similar cowling from a 1100SS was used to replace it, or that someone replaced the clamp bracket with an earlier one. The key would be if the serial number on the clamps matches the one stamped on the block (I think it would be on the top of the block, near the rear). The model comes up as a '66, but the serial a couple years older. Something's not quite kosher in Mercville...<br />- Scott
Walter
Good point Chinewalker...<br /><br />AFDan's original post said it was 100 hp. even though it was a model 1100SS. It does make ya wonder if the cowling's been swapped.<br /><br />Walt
AFDan52
Chinewalker you made a good point, I will check out the block number abd compare the serial to see if they check out. I will let you know what I find out. Thanks for the tip. AFDan52
