I have a 1980 Cobalt with a 260 Mercruiser V8. This past summer I began having problems with battery maintaining charge while operating. I think the problem might be with the alternator, but someone else suggested a problem with the voltage regulator.<br /><br />The battery will take a charge when I hook it to a charger, indicating to me that the battery is good. <br /><br />The boat's amp meter moves slightly to the plus side when running, indicating to me that the alternator is putting out.<br /><br />However, after about an hour's run the engine will stall if I try to idle, and the battery is dead when I try to restart.<br /><br />I'm not a mechanic - the last engine I worked on successfully was the flat head V-8 in my 1949 Mercury in 1959! I recall from that experience that there was a generator and a separate voltage regulator. I understand now that alternators have built in voltage regulators.<br /><br />If the battery is good, and the alternator checks good, what should I check for then? <br /><br />Thanks - JeighC<br />
