RIDEPATE
Thread starter- Joined
- Jul 8, 2001
- 324
o.k guys here's the important info: 72 merc 650- not charging battery-what i've done:i had supisions that the system wasn't charging due to some flat batteries,replaced the battery ,found stator wires were completly rotted with no insulation,replaced the wires best i could, i cut what was left of the wires right at the stator and replaced with new,excuse me for calling things "boxes"but until somebody tells me what these "boxes" are called i will just reffer to them as such,the two stator wires run to a epoxy filled box "box" with a volt-meter i'm showing 6+ volts coming off each side of the stator, the epoxy "box" which the stator wires are going to has a red wire going from there to a bigger "box" on the front of the motor,i really don't know where to go from here,i also did the old auto charging test, took the groung off while the motor was running and it dies instantly, ive ordered myself a manual which hopefully has some electrical troubleshooting guides in it and if any body can tell me what these boxes are called that would help also.thanks in advance.jim
