ChampionHead
Thread starter- Joined
- May 5, 2002
- 27
I have a 1985 Mercury 150 HP outboard. When I run it at idle (but in gear) the temp gauge reads about 1/2, but when I give it a little more gas (not enough to bring it on plane) the temp gauge moves up to 7/8 to HOT. If I put the boat up on plane, the temp gauge runs in the range of 3/4 to HOT. The water pressure is running about 15 PSI to a max of 18 PSI. As I give the engine more gas the water pressure moves up to 20 PSI briefly then backs off to 15 PSI.<br /><br />I've replaced the thermostats and there is water coming out of the pee hole. The problem was much worse before I replaced the thermostats because no water was coming out of the pee hole.<br /><br />Any ideas? Do I need to replace the poppet?
