NEED YEAR 60'S MERC
deli man
i HAVE A MERC 950 KIEKHAEFER SERIAL #2016735,THUNDERBOLT 6 CYLINDER.I NEED TO KNOW THE YEAR IT WAS MADE AND HOW OFTEN SHOULD THE POINTS AND CONDENSER BE CHANGED.THE ENGINE STARTS,BUT AFTER A WHILE WHEN YOU WANT TO OPEN THE ENGINE UP IT BOGGS DOWN.ALSO HOW OFTEN SHOULD THE FUEL PUMP DIAPHRAMS BE REPLACED?ALSO IS IT HARD TO REPLACE THE STEERING LINKAGE,AND HOW DO I GO ABOUT THIS.ANY HELP WOULD BE APPRECIATED.
Bear
Re: NEED YEAR 60'S MERC
950 (95,0) #1869776 - 2097279 is a 1966 6 cyl inline.<br />The best advise is to get a manual. See the top of this page.<br />Exploded views:<br /> http://www.mercruiserparts.com/select_docs3a.asp?doc_nbr=+39964+++ <br />There might be some useful info for your 950 here:<br /> http://www.maxrules.com/fixoldmercindex.html <br /><br />If you press the bulb when it bogs down and it picks up again it's time to change the fuel diaphrams.<br /><br />Good luck!<br /><br />/Bear
