miguel agullo
- Joined
- Jun 26, 2002
- 2
Hi all,<br /><br />I've got a Mercury 2 hp Lightning outboard attached to a 15 feet steel ex-fishing hull to cruise the (sweet water) canals in Amsterdam. The other day I pulled the engine out of the water after realizing it had eaten a plastic bag (even though the motor continued working.) Removal of the prop showed the remains of a second plastic bag wrapped in the axle.<br /><br />While I was removing this mess, my boating partner jumped on board and the next thing I know is the outboard is fully submerged in the water (except for the prop end of the shaft). I pulled it out, left it on the boat for 12 hours and came back the next day. I drained the gas tank and the engine of all water / oil, liberally sprayed dampstart spray, cleaned the spark plug. And it worked.<br /><br />After some stuttering, it went on for about 3 hours. A couple of times it seemed like it was going to die, but moving the throttle up and down a bit got it back to regular cycle. As we were about to dock, the engine died while idling. It has not started since.<br /><br />I've taken apart the carb, etc. but I don't see anything obvious (second hand motor, but looks pretty new inside). Sprak plug works ok.<br /><br />And finally the question. If I open tank valve, the oil leaks from the float bowl drain screw. This does not happen if I tighten the screw. The screw has a spring between the screw-head and the carb casing and I am pretty sure it was not tightened all the way before. But the motor vibrates quite a bit, so much so, in fact , that the screws that hold the plastic outer casing of the motor sometimes come off. I'm wondering if this drain screw also got unscrewed and should be screwed tightly.<br /><br />Also, since the massive leak started when the motor died, I've been relating the two of them. Maybe by screwing the drain screw I get rid of the leak and by having cleaned the carb I'll get the motor running. Since the leak was still there when I put the motor back together, I didn't try to start it.<br /><br />Anyway, any ideas would be appreciated. I've been told by a Merc dealer this is a pretty crappy motor (he wouldn't repair it). It cost me only 60 bucks, but if I get it to work again, it is definitely a lot more valuable.
