1989 70hp mercury will not start!
Rinker
I was out running for an hour,stopped for a break,my wife went to restart it and it just cranked so I switched :confused: gas tanks and pumped the ball and I tried to start it pushing the key in,no start.I asked her if she pushed the key in while cranking she said yes.<br /> I said it must be flooded,we waited I tried again later and the same no start.So we were towed 6 miles to our ramp by a family member,at that time I was trying with choke without choke finaly I gave up.<br /> Next day pulled plugs,they were gas wet,so I put clean used plugs in crank,no start,remove plugs they were wet ,so I removed the plugs cranked it without plugs thinking it would clean out the cylinders,blew out the holes with air,installed New plugs,crank it no start.Now I have checked for spark several times on all clinders and have good spark,I also checked compression an even 115psi, I am lost I have fuel spark and compression but It wont start ,it just wets the plugs with fuel? it ran normal before and aways starts instantly
BKool68
Re: 1989 70hp mercury will not start!
You may have sheared a flywheel key.
Rinker
Thanks I will go out and check it. Any ideas are helpful!
russthemuss
Make sure its cranking fast enough.
Rinker
I have no way of removing the flywheel nut its too tight, but I looked at the prop and it smells of GAS? Im lost here , compression,spark, fuel, no start just floods,I called the dealer but they can not look at it for 2 weeks! :confused:
Trent
Im with Russthemuss..<br /><br />Connect jummper cables to your battery and re-test! These engines MUST have full cranking speed to start correctly!
Rinker
:rolleyes: now I have no spark ,I checked it with plugs in and put a new plug to the wire and ran a ground to the plug cranked it and no spark ? oh well boat goes in this weekend to the dealer.I hope it does not cost a mint to get floating again summer is passing me by and I have a dead boat :mad:
Rinker
It Runs again! :eek: Here it had spark all along the trouble was said to be water in fuel !(Long Story!)
