Re: mid 70's 3 cyl Mercs
Sometime in the 80's when they prop rated Mercs, they were derated to 60 HP permanantly. They only had 49 cubic inches as I recall. I think they were made rite upto the 90's though. Then they were replaced by a 59 cu inch 3 cylinder that has THREE carbs, then the 49 cu inch was dropped. The new 59 cu inch block comes in three flavors; 40 hp, 50 hp and 60 hp. 40 and 50 are the same except for carbs and no reed stop on the 50. The 60 has some more mill work to the ports plus even bigger carbs. As of this date, these engines were discontinued this summer except for "stock" at distributors and Merc......(4 strokers replacing them...)<br /> You have roughly a modern day equivelent of a 60 HP. Decarboning this engine and making sure you have a good ignition system and well tuned carbs makes your particular "looper" run very well at higher RPMS. Sycronising the carbs was always a problem with your engine because of the unique setup. But once its set up rite, they ran very well when allowed to "spool" up to 5,500 rpm or more
