carb problem
viperman1
1974 merc 50 hp my boat sank last year and now it wont take in fuel when i prime the bulb it com es spitting out of the engine any help would be great
dymo
Re: carb problem
First question would be, where is the fuel coming from. I mean, where on the motor?
dymo
Re: carb problem
If the fuel is coming from the little hole on the upper side of the carbs, I would say it's a stuck needle valve or float restiction.<br /><br />I had somewhat the same problem and found that I had a sticking float. Verify that the floats and needle valves are moving without restriction.<br /><br />Dymo
viperman1
Re: carb problem
im a new boater im not sure what to look at how can i see if the floats are stuck or check for what u just said any help would be great thanks
viperman1
Re: carb problem
Whitlers
Re: carb problem
As a new boater the best advise I could give (And please dont take this wrong) is to get a GOOD service manual. To check the float you will have to remove the carb. remove the bowl on the bottom of the carb there you will find the float. Invert the carb and make sure the float is parallel to the carb housing. while you have the float exposed you will want to revome the float and make sure the float needle is clean and the port is not cloged.<br /><br />Hope this helps.
