Engine explosion
Tom Ostermann
Our problem is with a 1998 135 Mercury Optimax motor. The last two times we've had our boat out, we have experienced explosions in the motor. The first time was about 6wks ago, and then again yesterday. Both times we had gone to shore and stopped for about an hour. Upon restarting the engine an explosion occured, strong enough to blow the engine hood up about 10 inches and crack the fiberglass this last time. The first time it was just a loud noise. Following the explosion there was a significant amount of smoke under the engine hood. We did restart and the engine ran OK after both occurances. After the first time, we took it to the shop and they couldn't find any problems. Both times we had a sensor light up while operating the boat. The first time, was a check engine light, and the second, was a temp light. We stopped the motor both times and looked under the hood, then replaced it and restarted the motor with no reoccurance of the sensor problem and headed to shore. :eek:
Greg Lawrence
Re: Engine explosion
dood. that sounds like serious. i bet you got a gas leak, that would make a good explosion. what about fire?
iRich
you have two things;<br />1. A gas leak<br />2. A spark coming from somewhere it shouldn't<br /> I wouldn't take this boat out on a bet until you get it fixed. find a new mechanic.<br />Rich
sloopy
gas does not explode, the vapers do?!?!? something is Kooko! you said it happened two times and then stoped??? Did you notice any decrease in performance befor the load bangs and the cowl flying in the air? sounds like the a leak in the gear case? the powerhead? the Injectors???
rickdb1boat
Please take it to a reliable Mechanic!!! The Money you spend may well save your life! Good Luck,
had this happen to me once on a 12.9 chrysler it was a leak in the fuel line diffenatly dont run this outboard till its fixed it could blow you to kingdom come. clean the motor off with engine cleaner and flush the motor off with water making sure you dont get any water in carbs then pump up ball and see if you can see wher the gas is coming from hope this helps
Greg Lawrence
yeah this kind of thing scares off the fishes for sure. you wont catch very many like this.
iRich
sloopy, you are proof that there are rare cases when abortion can be justified.<br /><br />Rich
brother chris
Just a thought...you have a gas leak, and then something has a short in it, and the gas staying under the hood creates vapors...and...BOOM. <br />Just my theory, but get it fixed before we don't hear from you again. :(
Hooty
How had you been running the engine before you stopped? Wfo? Trolling? Cruising? Duplicate that first and then removing cowling and check for fuel. May not be a leak. Could be blowing out carb(s). <br /><br />c/6<br /><br />Hooty
rickdb1boat
Good advice Hooty. The only thing I would do different is try to run it WITHOUT the hood on and see if you could find a leak. Might be a bit safer to let the fumes escape, so it does'nt go BOOM!
rickdb1boat
Also, if there is a leak, I would try to find out what is igniting the Vapors.
Hooty
The thing about running the engine w/o the cowling is it runs real lean. I figure it's getting ignition from a sparkplug wire either at the plug or coil. If he just runs the engine to duplicate what happens before the big puff and then removes the cowling without re-starting, he'll be o-k.<br /><br />c/6<br /><br />Hooty
rickdb1boat
True! As it only does it on start-up. Should be able to see something then.
Hooty
It'll be interesting to find out what iz goin' on.<br /><br />c/6<br /><br />Hooty
RICKRICK1
Ensign
I would also check to ensure the srater is mounted properly and solinoid is ok and all wires are tight.
P.V.
Hummmmm, You should take that engine to a good, reliable dealer who knows how to take the hood off, Oh, that's right, it's already off!! And tell him that HE should check the darn thing out as you value your life and will not do the troubleshooting for Mercury !!!!! Create a papertrail for resolution of this problem. If the dealer can not find anything (then he ain't looking hard enough), or even if he can, have him contact Mercury.
