is my motor smoking normal
Crupi
motor smokes when i have it out of the water with the muffs hooked up its like black mist is this normal?? its a 85 hp merc around a 77 model i just got the boat and it runs but not real well<br /><br />thanks
sloopy
Re: is my motor smoking normal
sounds like it is running just fine :)
Crupi
ok cool it does run badly tho but i just wounderd if it was normal for the blackish smoke like maybe it was to rich r somthing <br /><br />thanks for ur help
Walker
Black smoke is bad. Smoke should be light gray to white.
sloopy
wait! were is it coming out of?
Crupi
comes out of where the prop is so black smoke is maybe to rich?
Crupi
what does it when when the smoke is black any ideas?
Reel Appeal
Crupi,<br /> Check the carburator floats and needle valves/seats.Unless your outboard is a diesel(kidding) there should be no BLACK smoke.Blue to gray is Ok.Black smoke out of the exhaust is un-burned gasoline.SO,either it's gettin too much gas(probable) or not enuff spark energy. ;)Does it use alot of gas?
Crupi
well i just got the boat it runs rough and i can get it to stay running but when i put in gear it stalls out.. they told me they cleaned the carbs maybe they got the settings screwed up
Crupi
need help... could a bad diagham make it blow black somke and die under load friend at work was saing that could be the trouble?
