Have a 18ft. fiberglass with v-front and flat bottom; 115hp with hydro foil fins at the cavatation plate. Cannot go OWT with out porpoising or cannot avoid porpoising at top end speed. the bow goes up-and-down even on flat water. note the mechanics lower the motor at its lowest seeting assuming it would help. I haven't tried going the other way by elevating the motor? <br />The maximum trim angle at OWT could only described by the top of the merc cover is approx zero degrees (flat). Any little ajustment with the trim i start porpoising. At slower speeds the trim angle can be more generous. i've noticed on most boats the motor cover angle is pointing down towards the front of the boat. Do i have real problem or am i being greedy with the trim and acceleraion.<br />note: my maximum speed is 48mph with porpoising and without porpoising its 43mph..thats a big difference. HOw can i achieve max speed without porpoising?<br />Any suggestions guys.
