Re: Looking 4, Mercruiser 470 series Alternator & bracket to replace the stator
hey fastpastor,
Could you elaborate on how you do this? I have a 19' 1986 Stingray with the 190 hp 4cyl mercruiser, it has power steering. I looked at this for a couple of minutes and realized i'm no boat mechanic, yet I would like to research and solve this problem myself, as I am pretty self supporting, and fairly broke !!
A $150.00 sounds much better than the $384.00 from the other site.
1. I'm not sure where to mount the alternator, no good place just jumps out at me, it appears the coolant overflow tank would be about the best spot.
2. I assume I may have a water cooled regulator as stated above? Can you provide any info that I should be aware of.
3. Maybe I'm ahead of myself, but I assume my stator is bad, as soon as the boat gets disconnected from the battery, it dies. On full batteries we get almost a full day before we are jumping the motor from another battery. Is there anything else I should be looking at? The motor runs just fine.
Thanks for the advice in advance, as the more i can save on boat repairs, the more time we can spend on the water.
