Re: TILT AND TRIM
Your in luck, I just went through this on mine.I hope I can explain it. The problem is when the motor goes up ,the blue goes to + and the green goes to - . And then going down the green is + and blue is -. You only have two wires! You need a switch that has 6 connections. Its called a "MOM ON OFF MOM ON" Now ,from the battery run a red + and a black- wire to the switch. Using terminal lugs attach the red to the left center post. Attach the black to the right center post. Attach the green to the left bottom post, and put the blue on the right bottom post. Now using a jumper connect the bottom left green to the right top, and jumper the bottom right blue to the top left post. It should go up when the switch is up and down when the switch is held down. You do have to let go when you want it to stop. There are no limit stops.( big deal). Mine works perfect, Hope this makes sense. I could fax you a drawing if you need it. Good luck Bruce
