This message was started a couple of weeks ago and was deleted by Steve along with all the other recent posts.<br /><br />I have a 1994 SportJet 90 with the Force 3 cylinder powerhead. After running for approximately 10-15 minutes the engine seems to drop a cylinder and then totally stalls. It will start again and runs fine for only a minute and then stalls again. This goes on and on like this if you take it above 2500 or so rpm unless you let the engine sit until cool. It drops a cylinder and stalls unless you keep it around 2000 rpm. Seems you could drive like that at 2000 rpm all day.<br /><br />I thought it was the fuel system for a long time. It's not. Carbs rebuilt twice, new check valves and diaphragm in fuel pump and in lines.<br /><br />New ignition switch and harness<br />New lanyard kill switch<br />New red stator<br />New red stator adapter<br />New rectifier/regulator<br />Rev limiter is OK. Stalling happens even with it unplugged.<br />New switch box. I thought this was the problem when I last posted on this topic. Well, the new $200 switchbox acts the same as the old one.<br /><br />Compression when engine is cold:<br />Cylinder 1 is 130 psi<br />Cylinder 2 is 90 psi<br />Cylinder 3 is 137 psi<br /><br />Is it the bad compression on cylinder #2 causing me these problems? I can't check the compression with the engine warm, so I don't know if it's dropping when warm. Does compression normally drop when these engines become warmer?
