power loss from shoot not full speed
mduvall219
i have a 97 mercury 200 carburated engine. <br />bogging down out of the shoot. takes 10+ seconds to plane with more than one person on the boat.<br />with three people have to use trim tabs to get on plane or have someone goto front. <br />but i have no problem with top speed. once on plane it runs just fine.<br />got a 100 hour tune up and still have problem.<br />any suggestions would be great
dick
Re: power loss from shoot not full speed
Did they check the compression when it was serviced ? and did this proformance problem just start suddenly ?
ob
What pitch prop are you running?Too steep a pitch will cause same condition.Consider looking for carb linkage out of adjustment.Poster above asked important question.Did it recently begin this symptom or has it been this way since you've had rig?
Dhadley
Start with the basics.........<br /><br />What's the top capeable rpm with an average load?
mduvall219
well i have a 17 pitch prop<br />it has been like this for about two months<br />it wasn't like this when i got it<br />i have had it for 8 months<br />i haven't gotten anything checked other than just a 100 hour checkup<br />i have had 6 people on it with no problems before<br />i am able to get about 6000 top rpm's at full throttle and trimmed up
ob
Have the following checked out or perform yourself as per manual specs:carb link and synchronization,and low speed jets and porting.
