Re: Mercury 150hp Mounting measurement
Extra 260,<br /> Your assumption is correct.Why not get a 20" motor to better fit the boat?The idea of a transom jack is to raise the prop slighty out of the water at high speeds,therefore giving less drag.They are usually used for high performance race boats and the like.Is it a race boat of some type?If you are mechanically inclined you could also get the 25" motor and find a 20" leg, driveshaft,shift rod,(cut down the water pump tube)making it a 20" motor.The driveshaft should be easy enough to find,the leg may be a little more difficult.Good luck.
