My 87 60hp merc (3 cyl, 2 carb)has never had a very strong tell tale stream and after it had been stored for a few years I replaced the impeller and added a water pressure guage (0 to 15 psi). The guage will not even come off the peg at idle and at 2500 to 3000 rpm will come up to 2 or 3 psi. The manual says this engine should develop 3 to 5 psi at 5000 rpm, which just doesn't seem right
and there doesn't seem to be a cavity for a thermostat or poppit valve to raise the pressure. Does anyone out there know this engine? and is there any way to raise the water pressure.<br /><br />olmerc
