1986 9.9 hp Mercury outboard motor
Frank G.
Have replaced plugs, coils, switchbox assembly. Refilled with all new gas. Still will not start. What else is there to check?
ob
Re: 1986 9.9 hp Mercury outboard motor
Billy john, Have you checked to see if you are getting spark?
JB
Howdy BillyJohn.<br /><br />First, remove your plugs and spin it over. You should be able to get a 1/2 to 3/4" arc from each plug wire to the block.<br /><br />If you have good spark, spray some fuel mix into the carb and see if she tries to start. If she does, you have a carb or fuel supply problem.<br /><br />Let us know what you find and we will take it forward from there.<br /><br />Good luck. :)
