bigcat1061
Thread starter- Joined
- Jan 14, 2003
- 10
i have a 120 sport jet in a bass tracker pro jet 18 1995 model.cranks good when cold --runs great--but after you run it and stop-it will not crank back after you turn it off--if you let it set about 5 minutes it will crank but its hard starting sort of like its flooded-- but when engine has been run and turned off it will not crank back right away--i have unpluged rev limiter but same problem. on the key switch does the push in feature control choke or some kind of fuel primer--when you push in on the key switch i doesnt click like the older push to choke motors i have had
