Mercury 150 Cannot start anymore
necman
I was able to start this motor several months ago. I think my starting battery is good, it shows over 12 volts anyways, but the motor just barely turns over when I hit the key. Any suggestions. It turns over a few times and then it seems like the battery goes dead. I do not know much about boat batteries to know if even though it reads 12.3-12.5 volts, can the battery still be bad? :(
Trent
Re: Mercury 150 Cannot start anymore
Yes it can be bad. Take it to a autoparts store and have them load test it and also use a hydrometer on it.
kris_merc
At one point, we had similar symptoms with my Dads 90 hp Merc. Turned out to be the brushes on the starter motor. Took it to a guy in Aransas Pass that had a bunch of old Mercs, and to our delight, he sold us just a set of brushes, and fixed it for about $50 bucks I think. Just my $.02
necman
I did load test it with my neighbors load tester, which seemed to show good, just makes no sense. What else would cause it to be sluggish. I just do not feel that something major could go wrong in just a few months sitting in the drive way.
JB
Measure the voltage at the starter when turning over. If it shows over 12V your starter is bad or the engine is trying to seize.<br /><br />If it shows below 10V you have a poor connection in the high current circuit.<br /><br />Good luck. :)
necman
Sounds good, that will be my next test. Also, I will try a brand new battery. When I popped the tops on these they were low on fluid, I refilled with Distilled water and re-charged. I will try the voltage test at startup.
necman
What shall it read if everything is ok?
