John In Wisconsin
- Joined
- Feb 12, 2003
- 4
I have a 1979 (I think..may be slightly older) , 90 HP Mercury outboard Model 900 that will run very smooth, then occasionally when running at higher speeds, all of a sudden something happens and engine RPM and speed drop significantly, then sometimes after a second or two, the motor takes off again to orignal speed. The motor does not completely stop and does not sputter or miss, It's like someone takes the throttle and pushes it back half way real fast, then goes back to full throttle. Seems to happen more after I boat for a while and engine is warmer. Replaced fuel lines, plugs, distributor cap last year trying to fix it, no luck. Compression is good, and it does run and sound great, except for this problem. Thinking it may be an electrical problem or the fuel pump (never had worked on yet) ? I also had fuel problems around the same time, bulb woudl go flat after I stopped engine for a while, replaced fuel lines at the end of the season, dont know if bulb problem is completely fixed yet, still "drops out".
