Re: Mercury 115hp hardstart
smike26 <br /><br />I didn't see this post before I replied to your "request for advice" post. I am not surprised to see that you are having cold start problems with this engine. Believe me you are not alone.<br /><br />First, make sure the choke plates are working. Not only should they operate smoothly, they should fit snugly against the carb opening. If there is a lot of slack, tighten the pivot bolt down until the choke plate still operates smoothly, but the plate is held down snugly as possible over the carb opening. With my 115 I found that the tag end of the choke solenoid cable would often hang up on the choke linkage. A bit of "adjusting" took care of that problem.<br /><br />If you find that your engine is still hard to start after optimizing the choke, you can carefully spray some pre-mix fuel into each carb. It helps if you will tilt the engine all the way down, so the fuel will flow into the carbs (this seems to help a bit even if you are not using the squirt bottle).<br /><br />After getting tired of pulling the cowl (the first time of the day) I installed a primer system on my engine. It consist of a 1 gallon fuel tank, a 1/4 size fuel hose and squeeze bulb(you can buy a bulb at WalMart), three spray nozzles and a couple of 1/4" tees to route the hose. I installed a brass fitting with a screen as a pick-up tube, tie wrapped the 1/4" hose alongside the throttle cable and fit the spray nozzles into the carb opening screens arranged so the choke plate wouldn't hit them. Now, first thing in the morning I prime the regular fuel hose, squeeze the "primer" bulb a couple of times and she starts like a 2003 model!<br /><br />Seriously, now she starts so well that I do not even use the "warm up" lever any more.<br /><br />The parts for this simple primer system cost me about $10.00. If you do something like this be sure to do good quality work and remember just how dangerous gasoline can be.<br /><br />Good Luck,<br /><br />Gold Bear
