takidd4597
- Joined
- Feb 27, 2003
- 5
I have a 1988 Mariner. It is a 3 cylinder. I have been getting and alram on my throttle control. It did it one day when I was trimmed down and when I trimmed up it went off. Today while we were out I was having a problem with water in the gas and the entire time the alarm was going off. Could not get on plane until I worked the water out of the carbs and line. The motor was just worked on and they put a new head gasket on.. Supposedly for the same reason. I have a stream of water comming out like a garden hose. I can keep my hand in the stream of water. There is no way this water is over 120 degrees. This is a 60 hp Mariner 1988.<br /><br />I have one wire next to the top cylinder with an very small thin nut. I mean it is very very close to the top spark plug. They told me the impeller was replaced as was a new head gasket.<br /><br />Is there a certain temp the pee water should be to tell if it truekly is overheating?<br /><br />Help please. <br /><br />Can anyone tell me what could be causing this alarm and why and what I can do to fix it?
