I recently purchased a used boat with a 115 hp 1998 Mercury engine (w/low hours). It runs well and fast to the fishin' spot but on the way back only 3/4 speed. It won't get up on plane. I replaced the plugs and added fuel cleaner but still the same. Also, after I purchased it I noticed a wire in the engine that was disconnected. After I connected it the alarm would scream as I started the engine, both cold and hot. I have plenty of oil and the spitter works. Should I be concerned
and do you have any suggestions about 3/4 speed? Thanks, STACK
