TONY ON ICE
Thread starter- Joined
- May 1, 2003
- 3
This is my first Mercury outboard (Modern) and I've got this water problem.<br /> The motor is a 1991, 75 HP Tiller, 3 cyl.<br /> When running with the muffs in place, I found the tell tale hose plugged and no water coming out at all.<br /> At the same time, there was water rushing out of the lower unit near the shift shaft and from a small round hole in the lower unit casing that's right behind the shift shaft.<br /> I thought that when I unplugged the tell tale hose that the excessiv water would stop and go to where it was supposed to but it's still coming out like a gusher even though the motor is circulating water and has a full force stream at the tell tale.<br /> Could this be a water pump seal or a grommet on the water tube ?<br /> Will it hurt the motor to run it like this until I can get it into a shop ?<br /> It's the walleye opener here in NY. at midnight tonight and most shops are booked solid for a few weeks. <br /> Any suggestions would be greatly appreciated.<br /><br />Thanks in advance !!
